AXISVM X7r3 - New Features in BIM
edited January 31 in CAE
Rhino/Grasshopper
GrasshopperToAXISVM add-on version 7.0
► optimization of beam structures (access to SD9 and TD9 module functions)
► transfer certain AXISVM analysis result components to Grasshopper
New interface for V6.0 Rhino/Grasshopper
New features and options available in GrasshopperToAxisVM V6.0:
IFC
Additional import options
New options are available for importing an IFC model:  Overwrite, Add, Update.
Export of special domains
The IFC export option is available for ribbed, hollow core, composite ribbed, and trapezoidal steel deck slab domains.
Revit-AXISVM
Support of Revit 2024
The supported file versions have been extended with Revit 2024.
AXISVM transfers the model data using the API interface of Revit (Revit 2019 or a newer version is required).
Export of actual reinforcement to Revit 2023 and 2024
With the enhanced transfer the following data and elements are exported:
Revit-Dynamo
New interface for V3.0 Revit/Dynamo
The components available in the new interface support all AXISVM elements and load types.
